2007 Vortex max build help
Old Jun 22, 2023 | 05:47 AM
Troymatthews96_'s Avatar
Default 2007 Vortex max build help
Hello all i have found a low mile Vortec max with a L76 6.0, i am looking for some recommendations on a daily driver camshaft that will be able to tow. Just looking to wake the truck up a little and have a decent lope from the exhaust. I am not against getting better cylinder heads if i can find cheap OEM's, don't know much about these things so any info would be great.
Old Jun 22, 2023 | 09:56 AM
Try the Brian Tooley Truck Norris cam. Good power throughout the range, plus it does lope.
Old Jun 22, 2023 | 10:04 AM
strutaeng's Avatar
Looks like that engine was very similar to the LS2 and has AFM. Are you deleting the AFM?
Old Jun 22, 2023 | 10:16 AM
The L76 has both AFM/DOD and VVT, both of which need deletion if he wants to swap cams.
