New LS7 is hurting...
How to pinpoint the failure? Are people here saying a spark plug kissed a piston head due to length? Or thread pitch?
Anyone got an illustration?
I have bought three of these, one for me, one for my old man, and a spare, and they're worth their weight in gold. It says you can plug it into your phone but mine requires me to download some Chinese malware in order to use it, but if I plug it into my LAPTOP and just select "camera" from the search bar, it works flawless. The head is no bigger around than a pencil, and it even has a decent picture quality.
Also, your spark plugs have a tapered seat meant to make contact with (and tighten against) a mating taper in the head. The taper is also how it makes a seal to the head. They're saying your heads probably don't have a taper like that, but instead have a flat surface for a washer to set on. You can look inside the spark plug hole in your cylinder head and see whether the seat is tapered or flat.
Your spark plugs maybe have both the wrong length and the wrong type of seat.
I was also using the "wrong" plugs I just found out. I was using standard TR6 plugs. But I changed plugs pretty often and did not have signs of interference on any of the plugs until the ringland incident.
