Head torquing
That style of "bolt" works differently from what we were all accustomed to back in the SBC/BBC type days. Back then, a "bolt" was supposed to be an immovable clamping device, that you tightened until it clamped to the correct force, and once tightened to that point, it was never supposed to change. Problem was, things around it DID change. And when they did, the bolt was no longer clamping correctly.
TTY (torque to yield) bolts work DIFFERENTLY. Think of them as a SPRING: they're nowhere near enough "bolt" to function the same way they would have in the old days. Instead, you torque them until the tension on them exceeds their "yield" strength, by some controlled amount; and instead of "clamping", they now "yield" as the force on the increases, but retain the same tension at all times, even if the parts clearances change. They're like a REALLY TIGHT spring.
Mentally compare the way a worm-gear hose clamp works, to one of the spring type that you remove with pliers. Same principle. Worm gear, you tighten the crap out of it, but sooner or later, the rubber hose deforms, and it's loose. Spring type, it's never really "tight" as such, but no matter whether the rubber expands or contracts, it keeps the same tension.
