LS3 Cam recommendations
Old Aug 20, 2023 | 11:58 AM
tresguey's Avatar
Default LS3 Cam recommendations
Hey all, looking for cam recommendations. Aluminum block LS3 with a Scat 4” stroker rotating assembly. AFR mongoose heads. Hedman long tubes. FiTech up to 750 fuel injection. 4l80, the rear end not chosen yet, looking at Currie. In a 62 C-10 with a complete QA1 suspension system. Going to see the drag strip once in a while. More of a burnout and having fun truck.
Old Aug 20, 2023 | 04:26 PM
Your best bet would be to call either Summit, Cam Motion, Comp, or any other competent cam grinder and let them figure it out for you.
For what you want, there will be a shelf grind that will do what you want.
Old Aug 20, 2023 | 08:58 PM
vegas_ss's Avatar
Fill out the form and give them a couple days to get back to you...
Cam Motion Recommendation Form
Old Aug 21, 2023 | 08:27 AM
Jimbo1367's Avatar
You could also use Patrick G. He has a ton of experience spec’ing cams. But he has a fee. Not sure what he charges nowadays.
Patrick G. Or Cam Motion would be my two top choices. I could see using Darth from LS1-tech. He’s one of the very, very knowledgeable people. There are some others on here too. I just do t remember there names . LOL
Old Aug 28, 2023 | 11:34 PM
KW Baraka's Avatar
Originally Posted by tresguey
Hey all, looking for cam recommendations.......
With 11.7:1 static compression, I just went to a new cam;
238*/248* duration, 112* + 4* LSA......
IVO = 11*
EVC = 8*
IVC = 47*
EVO = 60*
Don't know HP numbers but the engine pulls all kinds of torque below 3500 RPMs.
Best of luck whatever you decide.
KW
