new water pump on LS3 ?
need to mount a newer LS3 water pump, with the water hose on the left (driver side), belt is getting near the hose.
is it counter clockwise ? does the turn direction be looked infront of the engine?
Thx !
https://www.summitracing.com/parts/ado-251-728
I am always thinking of an electrical pump, because in low rpm the water flow through the radiator gets less and the tmp rises, fans must start on....
- electr. pump to help the mechanical pump
- electr. pump instead of mechanical pump, same lookalike and hoses, idler pulley to run the belt
- electr. pump instead of mechanical pump, seperate idler pulley, complete different pipes for cooling an heating passanger room
