L92
Maybe with the right cam that can be offset a bit in your new engine.
You don't have to, but porting the stock heads would be nice. I'd be looking at a different intake suited for high rpm. Stock intake is going to fight you. Maybe a BTR trinity? Fast with mid-length runners would work too but I've never seen anyone sharing impressive results with that thing. Ideally you'd get a trinity and send the heads and intake to the same shop to port them together. Stock heads and out of the box trinity would also be ok.
What is your race weight with you in the car? You should be hitting mid 10's with this combo. It'll run real nice.
Watch your PTV, but as much as you can increase the compression the better.
This was our L92 combo in our 1980 malibu wagon bracket car. SBE with mild ported heads + victor jr and holley 750. 239/251 on 110+2 cam - slightly bigger than the F35, but not much different. 6000 stall 8" converter and powerglide - I think in that video was 4.56's. Only 10.4:1 compression. Race weight is about 3100-3200 with driver. Eventually ran a best of 10.13. At 131 mph it was screaming through the lights at 7800 - super fun. Now have a 415 in it because we think it broke a piston. Destroyed everything except the lifters lol. Made 760 runs and a lot of wins.
My advice is to call up the Lindy Tool Co and get the cutter for the intake valve, get .040 head gaskets, unless your pistons are out of the holes more than normal, and get the heads milled to set the compression to around 11:1, maybe more if you have more than 91 octane where you are.
This TSB is also useful reading for this engine: https://static.nhtsa.gov/odi/tsbs/20...33148-9999.pdf
It's probably smart to do the piston soaking that is talked about in that TSB. I had very good success doing it and not having oil consumption afterwards, and my engine looked like it was owned by someone who wasn't a fan of oil changes.
