408 ls stroker build
Old Jan 8, 2024 | 11:26 PM
Manny1990's Avatar
Default 408 ls stroker build
What are the best heads to go with the 408ls, im running N/A 4x4 300ft max.Currently have ss4 cam but need suggestion on what heads are the best bet and best lifters.
Old Jan 9, 2024 | 01:46 AM
B4CMaro's Avatar
Will need more information about what your goals are and what the primary vehicle use will be. Assuming 4x4 means suv or truck so I guess it's heavy?
In my application and experience, trick flow 255s produced good numbers for me with 403 cubes and more cam. If I had to do it again I would try a set of mast small bore ls7 heads instead.
225 cc cathedral as casts with a similar sized cam to what you have was pretty weak compared to new setup.
Old Jan 9, 2024 | 01:55 AM
Manny1990's Avatar
its a 01 jeep xj have a th3500 with transbrake 3800 stall its mainly for dirt drags.but looking for power to get out of the hole and little top end.
Old Jan 9, 2024 | 10:25 AM
B4CMaro's Avatar
I would go with afr 260s and ls3 gm intake or fast with long runners.
Should make great power from 3500 to 6500
Old Jan 9, 2024 | 08:24 PM
Manny1990's Avatar
okk thank you i'll start to look into the afr's or trick flow.
Old Jan 11, 2024 | 06:28 PM
Bob570's Avatar
Go with a small bore LS7 head. GPI has made 550+ whp on a stock bottom end LS3 with theirs, they call it their LS3 Max package.
Old Jan 11, 2024 | 11:25 PM
B4CMaro's Avatar
Small bore ls7 might be pretty good too. I haven't recommended them because I haven't used them and there isn't as much data or results out there about them.
Old Jan 13, 2024 | 07:31 AM
Manny1990's Avatar
do u think m311 frankeinstein heads will work good?
 Michael S. Palmer
