LS3 cast crank hp limitations
Old Apr 4, 2024 | 08:23 PM
f8lvenom's Avatar
Default LS3 cast crank hp limitations
Hi folks, I'm wondering what kind of power is a cast ls3 crank good for? Building an engine for boost and wondering if it'll hold 1000rw?? Thanks folks.
Old Apr 4, 2024 | 09:21 PM
01CamaroSSTx's Avatar
1000hp is doable with a cast crank. I wouldn't push it much further beyond that though and yes you can but for how long would then be the question.
Old Apr 5, 2024 | 08:17 AM
It’s relative. If it’s a tractor pull engine that will see 30+psi for 30+ seconds at 7500k rpm, then it’s not gonna live. But if it’s a typical street build that will see the occasional blast, then it will live for a long while. Gap the rings for boost. As 01Camaro said, it’s a time thing. It’s been done thousands of times with large success in street builds.
Old Apr 5, 2024 | 12:52 PM
f8lvenom's Avatar
It’s going in a Procharged Corvette street car. Good to know.
Old Apr 14, 2024 | 03:30 PM
gnx7's Avatar
I made around 1200rwhp with a cast crank and Compstar rods/Wiseco pistons running MAST LS3 heads and a turbo. It was a 1/2 mile event car mostly and was great for years.... I finally killed the crank by doing a 1st thru 4th gear burnout (showing around 140mph or so) and going maybe 70mph.... I let off the throttle still in gear... and when it hooked up the driveline shock cracked the 7/8 rod journal clean thru. The only thing holding the crank together was the rods. Luckily it didn't hurt the block (LS9) and I replaced the crank with a forged unit, 2 new rods, new rings/bearings and it lives on.
With a supercharged engine putting extra load on the crank snout I would do a forged crank for sure at that power level. Turbos are a lot easier on parts.
Old Apr 14, 2024 | 06:56 PM
BCNUL8R's Avatar
I've been running a stock ls3 block and crank with a 24t reluctor, k1 rods, and wiseco pistions for a few years now. Started with a d1x and moved to an f1a-94 last year. So far so good.
