Head gasket??
Old Apr 8, 2024 | 01:07 PM
SRB's Avatar
SRB
Default Head gasket??
Will a
Cometic LS 4.060 Bore MLS Head Gasket C5751-045 fit a standard bore LS3 or it that cutting it a bit close? The closest one I can find is a 4.100, a 4.080 would be perfect but I can't find one in .045 thickness.
Old Apr 8, 2024 | 01:22 PM
IGN-1A's Avatar
Default Piston Squish Distance
Hi, what is the distance between the piston Crown and the Cylinderhead ?
Old Apr 8, 2024 | 03:06 PM
You NEVER want a head gasket bore size smaller than actual cylinder bore (4.065 .in your case)
4.100 will be fine. .0175 outside the bore (increased radius) won't hurt a thing.
Old Apr 8, 2024 | 08:49 PM
Fitting the head gasket to the chamber diameter is more important than fitting it to the cylinder size. Too small a headgasket for the CHAMBER and you disrupt head flow by moving the gasket “wall” into the flow path. Always give the chamber the necessary room it needs to work…err to the larger gasket if necessary. On an LS3 style head, 4.080 is close to perfect. Ive used 4.100 gaskets on a few LS3 headed builds and it worked well.
