Update on 400 Mile engine
found this with only 400 miles on the engine. Every bearing has some sort of mark on it but this was the worse one. Crank is fine luckily. What would cause this with so low of miles. Thinking of taking it back to the builder and telling him to fix it but I want to see people's opinions on what could cause this. Thank you
What viscosity oil were you using??
How many passes at the drag strip??
How long was it sitting after build before you started it??
I hope you get this resolved quickly. The fustration of doing a major project then having it fail - builds us up stronger.
Please keep us updated and give the builder a chance to make it right.
I would recommend not ratting out the builder at this time.
Good Luck!!!
