Ls2
Old Oct 12, 2024 | 10:36 AM
Mike's70's Avatar
Default Ls2
Have problem with injectors, on first crank they never fire but stop cranking and crank again they will fire.
Another problem is computer does not go into closed loop.
Anyone have any ideas what could be wrong.
Purchased harness from Howell Engine Developments.
Any help would be much appreciated.
Thanks in advance
Mike
Old Oct 12, 2024 | 11:15 AM
zzracer's Avatar
Start with the basic stuff. Check your grounds, check all your connections. Make sure you are using the right crank sensor. Us Make sure you constant positive and switched positive is right. It's usually something simple that causes this stuff.
