2007 Yukon SLT
Old Dec 28, 2024 | 01:25 AM
NickDeezy's Avatar
Default 2007 Yukon SLT
Had a bad lifter tick so I had a DOD delete kit from AMS racing installed, local guy used HP tuners to shut it off through ECU. Piston crumbled out the bottom of the motor about a week later.
Just installed a used motor that ran good. Once installed I put in new spark plugs and wires. Getting P0351 P0354 P0356. Could this be due to shutting off DOD in previous motor & new motor still having mechanical DOD system in it? Swapped coils and problem didn’t follow so I’ve ruled that out. Just seeing anyone here has knowledge on this or ran into same type of issue?
Old Dec 28, 2024 | 05:35 PM
old motorhead's Avatar
2007 Yukon had DOD?
Old Dec 28, 2024 | 05:50 PM
NickDeezy's Avatar
Default Yes the 2007 has DOD
Originally Posted by old motorhead
2007 Yukon had DOD?
Yes DOD was on these motors, thats why I had installed DOD delete kit mechanically and shut it off through ECU
Old Dec 28, 2024 | 06:38 PM
2007 Yukon had DOD?
Most Gen IV engines came out in 2007 MY.
Old Dec 29, 2024 | 09:34 AM
grinder11's Avatar
My son has an '07 5.3 in a Silverado truck. Right at 100,000 miles. It has DOD......When it works right
Old Dec 29, 2024 | 06:36 PM
Bbknucks's Avatar
Check for bad ground. On the lower driver side of block
