A 700hp reliable LS? Help me do it.
Stock or close to it, sure. But anything with 100 more HP than stock, I don't know......
Do you mind an iron block? A Chevy LSX454 with a cam swap is a dead simple solution without the 3rd party risk of an independent shop, and would make a ton more torque to move you down the road. Seat of the pants I bet the 454 would be more fun and make more tire smoke lol.
Looks like a complete crate engine minus intake, oilpan, electronics and accessories is $14,750 right now.
…I didn’t know tipping hookers was even a thing? I met a friend of mine to pick up a block 6 weeks ago or so, that I was buying. We met at a gas station in a shady part of Atlanta. My buddy beat me there and was telling me that when he pulled up, there was a hooker in the parking lot that came up to him and wanted $26…she was pretty high end.
$26 high end!! If I ever got that hard up, they'd only get one tip from me, and.......never mind.... That's why the top power producers (except that DOHC 670hp C8 engine) from the OEM are all pretty much FI, so I agree...
I’m building a 1980 Z28 Camaro and its engine selection time. I’m going with an LS. I already have full aftermarket suspension, built 4l80e rated to 750hp and 9inch rear. This is going to be a mostly street driven pro-touring car. I don’t know much about LS engines so that’s why I’m asking this here. I’m no stranger to engines though as I’ve built several performance sbc’s over the years.
My budget for the engine, accessory drive and electronics is no more than $23k for everything minus starter and headers which I already have.
The Goal?
700hp on 92 pump gas and be RELIABLE. This will be a mostly street driven car.
Can it be done? If so layout some tried a true recipes/blueprints for an engine build using all new parts. I figured a good start would be to buy an assembled long block and throw some type of forced induction on it but those costs can add up quick or maybe not. Like I said I’m new to the LS world. Help me out guys 🙂
The Goal?
He was great to deal with over the phone before I bought, and answered a couple follow-up questions via email afterward.
Golen runs the engine on dyno before they ship it out, so you know it works. That was the key thing for my decision. I didn't want to have separate builder / installer / tuner all blaming each other if it blew up on day one.
I wonder how many of those 2-year-warranty companies will replace the engine if it blows up on day one, and how many would just blame the installer. Unless the motor was proven before it was installed, it might be hard to know whether it was built wrong or installed wrong. If you buy a full motor from Golen you know it was built right, because you have a video and the exhaust ports aren't pristine.
There might be other builders with engine dynos too of course, but Golen was the only one that had a proven recipe. He's also got a 454 in his own race car, which is nice.
You could achieve it with an LT4 very easily and it would drive great too. Main downside is the additional weight of the supercharger and heat exchanger parts.
We built an 11:1 416ci engine with 100% stock LS3 heads and intake/90mmTB/injectors and BTR Stage3 cam with crappy mid length headers backed by a crush bent 2.5" exhaust and it made 560rhwp thru a T56 Magnum and 335/30/18 rear tires. He wanted more so a few months later he had the intake ported and rod modded, same 90mm TB, hand ported heads by a local porting guru, custom cam, 3" dual exhaust and it made something like 595rwhp. That would be the most budget way to get to 700hp flywheel. This is the truck:
It now sports an AHP 442 LS that makes just under 800hp but that was close to $30K with the Dailey billet dry sump setup, plus new wheels, bigger brakes, IRS 9", all kinds of additional mods.
I appreciate all the feedback guys. LT engines are not an option because I already have a swap kit for LS and nice 1 7/8 LS headers. I also don’t want FI ((even though it would be nice) because an FI setup adds up quick $$$. I also have a brand new 4l80e rated for 750hp.
I think its going to come down to Golen or Shafiroff. I’ve tried messaging Golen a few days ago but haven’t heard back. I’ll try calling him next week and talking. I think my best bet is a 454 or 427. Out of curiosity why all the hate for Borowski?
We used 5/16 in my engine posted above. It runs just as it should. No issues. I upgraded to 11/32 only because I had already paid for them from Tony.
I did a thick wall 3/8 to 5/16 taper pushrod from Manton on a solid roller cam with beefy 1237x springs 585 lb open maybe more with the lift I have. I needed the taper for clearance at the cylinder head. Ran out to 7800.
No idea what my 408 is going to do, but I guarantee the 700 fwhp mark was surpassed easily.
I say 454
My LSX 427 11.5:1 on 93 octane is not making 700 fwhp maybe 650 fwhp and dynoed 540 rwhp @ 6200 rpm and 500 rwtq @ 5100 rpm.
CamMotion 243/251 115+4 .661 and .633
LME cnc ported Brodix BR7's 265cc cylinder heads
FAST LSXR 102
NW 102
KOOKS 2" headers with 3" TDE
I'm certain 700 fwhp can be made with a 427 but it will take more cam and larger cylinder heads to get there. I'd say there's 30K invested in the engine alone and that was ten years ago. If I had went the CID route I'm certain that I would have eclipsed 700 fwhp.
FAST LSXR 102
NW 102
I think if you go onto the BTR website or Texas Speed website and look up their stage 4 cam they have a 700 flywheel hp 427 build as the dyno for the cams they call the stage 4. It has old stage 4 and the new stage 4 which I think made like 10-15 more hp.
