L92 btr red hot head milling
Old Jan 29, 2025 | 07:22 PM
Bbknucks's Avatar
Default L92 btr red hot head milling
I have a l92 I'm freshing up for a swap project.
stock pistons
823 heads
Btr red hot cam 221/24X, .619/.617, 113 LSA
INTAKE LOBE LIFT @ TDC: 0.04730
Thinking about bumping compression with having heads cut
Does anyone anyone an estimated safe range i can cut with out having to modify pistons?
Old Jan 30, 2025 | 08:21 AM
02EBC5Z06's Avatar
You are going to have to put it together and check ptv (at TDC and about 5-10 degrees ATDC) to see what you can get away with. Normally, LS3 heads don't have much breathing room. You may get away with just using a thinner gasket.
Old Jan 30, 2025 | 08:53 AM
1988montecarloss's Avatar
Too many variables for someone to be able to definitively say if it will clear or not, measure the clearance you have now and go from there
Old Jan 30, 2025 | 09:14 AM
Bbknucks's Avatar
Yea...I have the shortblock here and the heads are at the machine shop now and he was asking me how much I wanted to cut if any... I could go get em and measure and bring em back
Old Jan 30, 2025 | 10:06 AM
02EBC5Z06's Avatar
You are going to have to.
Old Jan 30, 2025 | 10:49 AM
Bbknucks's Avatar
Right on thanks
