What valves for my ls7?
I recently picked up a Z06 that I'm rebuilding, my heads are with my machinist currently and he is installing bronze valve guides along with stainless steel intake and exhaust valves.
After doing more reading, I’m second guessing that setup. Some people say stainless intake valves are fine, while others strongly recommend sticking with titanium.
This will be a street car, I have BTR Stage 2 V2 cam with BTR .660" platinum dual valve springs. I’m also looking into rockers — is oem fine or do I need johnson rockers? The heads are 67cc heads.
As for valves, I’ve found brand new OEM titanium GM valves for about $90 each, and I’ve also come across Manley titanium valves. The Katech valves look great too, but they’re quite a bit more expensive.. so if the others are fine that would be best.
I'm just trying to figure out the best setup for reliability for a street car. I’ve read that new GM Ti valves can wear out bronze guides faster, which is throwing another question..
Any insight or recommendations on which direction to go would be much appreciated. Just want to get this build right the first time.
Thanks!
Now Manley makes a titanium valve that has a hardened tip that doesn't require the use of lash caps but last time I checked they were going for about $1400.
I have Br7 heads on the LSX and they have DelWest titanium intake valves and the exhaust valves are stainless steel. It also had PAC .660 lift springs and they worked well with stock rocker arms with bronze trunnions.
btw is delwest the original ti valves? im new to the ls7 stuff.
hope this helps.
Manganese guides are actually preferred over iron guides especially when using stainless steel and titanium valves due to their ability to dissipate heat and reduce friction because the bronze is a softer metal. Regardless of what direction you choose to go having proper valvestem to valve guide clearance is important.
