ASA Hi-Lift cam into an LS3
Old May 25, 2025 | 08:04 PM
dannyz's Avatar
Default ASA Hi-Lift cam into an LS3
So I have a Hi-Lift ASA cam in my LS1 5.7 engine with less then 12K on it.
I got a little hot with the nitrous resulting in detonation and said bye bye to the #4 piston.
So now I have a stock LS3 form an 2009 c6.
What do I need to do to use this cam in my new engine?
Old May 26, 2025 | 02:43 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Are you running a stock pcm? If so, the cam is the least of your worries. The crank will be a much bigger issue.
Old May 26, 2025 | 10:50 AM
OP- ^^^^^This^^^^^^
You need to deal with 24x vs 58x before worrying about the cam.
Priorities.....
Old May 26, 2025 | 02:57 PM
dannyz's Avatar
Originally Posted by G Atsma
OP- ^^^^^This^^^^^^
Priorities.....
I should have added that I already ordered the 58X-24X converter, the cam sensor extension, knock sensor relocation kit and MAP conversion adaptor.
But after some thought I decided to change it up a bit and go with the BTR Red Hot cam.
Should work out pretty good.
