Gen 5 crank in a Gen 4?
Old Jul 1, 2025 | 07:29 PM
MrBlod's Avatar
Default Gen 5 crank in a Gen 4?
I know the Gen 5s and Gen 4s are quite different but I got a call from my local machine shop and the crank is bad and the journals need some work. I found someone selling a 12674745 crank (which is apparently forged) near me for $150 hoping that it will work, If so that'd be great because I'd rather not drop $1000 on a forged crank
Old Jul 1, 2025 | 08:27 PM
Keith's Avatar
As far as I know, all you need is the different crank timing gear. Brian Tooley and SDPC sell them if I remember correctly.
Old Jul 1, 2025 | 08:46 PM
MrBlod's Avatar
4th gen and up should both be 58x
Old Jul 1, 2025 | 09:22 PM
Putting the L8T crank in a Gen4 build is getting pretty popular, so yes, a gen5 crank will work in a gen 4 iron block. The L8T crank has center counterweights which wont work in an aluminum block without a little work, but fits an iron block fine. I haven’t been in enough Gen5 engines to know weather or not if ALL the Gen5 cranks have the center counterweights. If you have an iron block, you should be fine.
Old Jul 1, 2025 | 09:44 PM
MrBlod's Avatar
Ah ok, I have a LS3 so that won't work then, welp. $1000 on a forged crank here I come
Old Jul 1, 2025 | 10:13 PM
Bob570's Avatar
Just needs a little clearance for the counterweights in the middle of the crank, if it even has them. I'm not sure that the 3.622 crank even has them.
Old Jul 1, 2025 | 10:22 PM
MrBlod's Avatar
$150 crank in question, I read somewhere that the snout was different too? so I'll need a new pulley?
Old Jul 2, 2025 | 03:19 AM
BCNUL8R's Avatar
This guy has a complete build he documents building a 5.3 with an L8T crank. It's been a bit since I watched it, but the things I remember was center counter weights, reluctor ring if using a 24t needs clearanced, and the snout. As far as the snout I can't remember for sure but either the balancer or snout had to be machined slightly. You will have to watch the series to know for sure. The snout issue comes up in a later video when he is assembling the long block. The 24t reluctor issue may have been in a truck doug video where he built one of these. I think truck dougs youtube is 4l80guy or something like that he is a member here.
Old Jul 3, 2025 | 11:47 AM
showdog75's Avatar
Just go 3.9 stroke. Tooley has a 3.9 crank for $800ish and call Tony Mamo and he'll hook you up with some Wiseco pistons.
Old Jul 4, 2025 | 05:47 PM
Busted Knuckles's Avatar
My shop just finished balancing my L8T crank for a 6.0L iron block stroker turbo build, balance job wasn't expensive with K1 rods and Wiseco pistons, I'll ask them tomorrow how much heavy metal it took. They also cut the snout keyway longer toward the first journal so I can use a double row timing set. I will have to use a later model flexplate but that's no biggie.
Old Jul 6, 2025 | 04:51 AM
BCNUL8R's Avatar
They discuss the snout issue a bit here. It's not just the keyway, but also the diameter of the snout is smaller causing the timing gear and harmonic balancer to be loose.
https://www.yellowbullet.com/threads/turbo-l8t.2689840/
Old Jul 7, 2025 | 04:22 PM
rkreigh's Avatar
l8t works fine with alum blocks the iron blocks need a bit of clearncing
l8t check all 3 boxes good fast cheap cranks hqave run over 2k hp, they are full ccw forged 3.86 stroke
wiseco has 3.90 stroke pistons, i hope to ceramic coat and make up some of the 4 thou
alum blocks with 3.8 bored honed liner with 1/2 studs should do it
fuel hoops if you need more ls9 should support an ez 1200 hoops more than the block cn hold
I'm also thinking of installing liners for a much bigger 4.1 bore and stronger but the liners are pricey and the block need 3-4k of mchibe work
thinking since the liners recommed line bore, getting doweled billet main caps and studs
should hold 2k or so with good bottom end with boostline rods
l8t craks need a special timing gear and 8 bolt FW or auto flexplate both are ez to get
scrounged up 3 alum blocks so we will see how fare it goes
2 of em look very clean and GTG with only a hone
one block has a score in one liner than might clean up with 3.80 bore if not it get's the liners
Old Jul 7, 2025 | 08:16 PM
Ok good to know. I got my crap backwards. I haven’t been in enough Gen5 stuff to be sure either way. Thanks for clearing my mess up.
Old Jul 8, 2025 | 12:54 AM
Keith's Avatar
You can do a 6.098" rod with a 1.215" DSS piston. K1 and Compstar have rods in that length. Or a 6.1" Oliver rod.
You can also do a 6.2" Molnar rod with a shelf 1.115" piston.
Plan to spend some money on mallory for balancing.
Old Jul 8, 2025 | 05:25 AM
BCNUL8R's Avatar
I don’t see this as much of a cost savings when it’s all said and done. You limit your parts selection for pistons and still haven’t addressed the possible harmonic balancer issues due to the snout being a slightly smaller diameter than an LS crank snout.
Old Jul 9, 2025 | 09:41 AM
slowride's Avatar
The problem with all the 6.100" rods is like 99% of them are .945" pin which most off the shelf pistons for longer stroke will be made for .927", then the cranks are 8 bolt on the flywheels side and finally the snout side needs the SDPC front gear.
I think you mean 0.040" here?
Old Jul 14, 2025 | 08:54 PM
truckdoug's Avatar
I'm running a complete stock L8T rotating assembly in a 6.2L block. You'll need a gen5 lower timing gear. I took the easy way and made up the .002" rattle room with green locktite. The keyway doesn't support it much so I would recommend doing it the right way if you plan on running a bunch of spring pressure.
essentially it's 400ci stroker for around $2000 all in (having built it twice due to no oil pressure first go around) If I break the stock pinner *** rods Texas speed makes a drop in kit, no balance needed.
ive grabbed a few other L8T cranks while they're cheap for future projects. 346 in an LC9 block with gen 5 heads ought to be a stock block contender.
or a 388 in an iron 6.0 block to fit gen 4 rec port heads would make killer power.
L8T stock bobweight is ~1700g so most combos won't need a whole lot of Mallory
Old Jul 15, 2025 | 06:16 AM
BCNUL8R's Avatar
Any issues with an LS balancer with the snout being .002 under?
Old Jul 15, 2025 | 12:58 PM
1988montecarloss's Avatar
subscribing
Old Jul 15, 2025 | 05:05 PM
If Mallory metal is in the recipe for balancing, expect the cost to be high.
