6.0 Sewing Machine noise, source found.
Old Aug 16, 2025 | 09:58 PM
Planefixer4's Avatar
Default 6.0 Sewing Machine noise, source found.
2014 Caprice PPV. DOD delete, TSP Stage 1 can, Speed Engineering long tubes....etc.
So, the noise is really annoying. I found the source of it....for the most part. As I was cruising at about 40-50mph, the noise is most prevalent. I took off my flip flops (florida) and slid my feet towards the firewall. As soon I hit the firewall....the sound diminished significantly. I thought I was losing my mind. So I did it again, same results. The next day, I had another person in the car....same situation, and they confirmed a noticeable difference in the noise.
Just send this out there because I KNOW we all hate the noise. GOOD LUCK
Old Aug 17, 2025 | 12:18 PM
wannafbody's Avatar
You think it's a vibration noise?
Old Aug 17, 2025 | 03:41 PM
No, it's not vibration. It's simply the valvetrain making it's normal noise that is exaggerated by stiffer valve springs, more cam lobes, and thin wall header pipes.
