Pressure drop & sender locations
My issue is that I am seeing a ~20psi difference hot OE cluster oil pressure reading and an autometer electric plumbed into the drivers front of the block (pre-filter/cooler). After a commute, 48psi on the autometer, 27 on the cluster @800rpm. Cold its about 10psi difference. What makes it worse is after some autox hot laps I saw it as low as 16psi @ 800 rpm idle & 218 oil temp on the cluster (while the aftermarket gauge read 40psi). The new autometer gauge pressure matches the mechanical gauge connected to my Accusump plumbed in the same location so I have faith in it. I just replaced the OE sender with a new AC Delco part and no difference.
Is a 20PSI pressure drop hot between these two sensor locations (with the filter and cooler in between) typical?
