2017 LS3 added LSA blower. Bent rods #1, and #2
The lower compression of the LSA allows more boost and resistance to detonation. It's my humble opinion that a boosted, stock internals LS3 will never make quite as much power as the LSA. At least, as much reliable hp. I think you're playing with fire running much boost on any 10.5:1 static squeeze engine. Keyword is definition of "much.".....
The LSA blower will make boost right off idle. They will make all the boost by 2k rpm.
LSA tune has very low timing in those areas.
If this is a stick shift car, that amplifies the issue.
Those rods can bend without you knowing it. Once they bend to a certain extent, the pistons **** in the bore and the skirts break. Then you know it!
Guys think the knock sensors will save ya. But the knock retard you see in a log file is just the response of the ecu. The knock has already happened…..
See the thread below......Last edited by grinder11; Nov 30, 2025 at 09:42 AM.
