706 heads on 6.0
Old Mar 20, 2026 | 08:48 AM
Carp's Avatar
Default 706 heads on 6.0
I’m rebuilding an LY6 short block for my crew cab. Looking for a torquey motor with clean idle. Running a 206/218 .555 117+5 cam.
if it worth sending the heads off to TPS to make them PRC 2.5 heads? They will deshroud the valves and add larger ones. They flow much better .400-.600 lift. Just trying to justify getting a basic rebuild or going all out on what’s the best route for my build.
Old Mar 20, 2026 | 10:21 AM
Kubs's Avatar
Good flowing heads will always benefit power and efficiency. Since you already have them, having them ported will get a lot of benefit vs the cost of new/aftermarket castings.
Old Mar 20, 2026 | 10:56 PM
dixiebandit69's Avatar
With those cam specs, you could just run them as-is and make great torque.
Porting and larger valves will make more power at 4K+ rpm; don't know how much time you will be spending there.
For the record, I'm planning to build a 6.0 with 862 heads in the near future.
Old Mar 20, 2026 | 11:20 PM
Keith's Avatar
Not just the flow, but the small chamber should get you some more compression which will help with the torque.
Old Mar 21, 2026 | 10:59 AM
wannafbody's Avatar
That's Richard Holdener's favorite stock LS head.
Old Apr 2, 2026 | 01:37 PM
Jimbo1367's Avatar
I agree. Keep the heads stock. Maybe a valve job at most.
It’s a torque motor. No need to port the heads you want small ports.
