Summit pro LS cam pushrod length?
Old May 6, 2026 | 03:31 PM
brandon6.0's Avatar
Default Summit pro LS cam pushrod length?
I just rebuilt a gen4 5.3 for my son's truck. We used the Summit Racing™ Pro LS Vortec Truck Swap Camshafts SUM-8728R1. Used there recommended .600 lift springs. Etc. Did a full dod delete everything needed etc. got down to measuring pushrod length and the crazy thing is im getting 7.400 length no preload with a checker.
We installed some 7.450 to try and it runs fine but is a lil noisy because from what we measured and preload etc comes out at .050" I normally run my ls7 lifters at .080-.100" But what's crazy to me is I've never had to go to a length like this. We have normally ran .7400 or 7.425 or shorter if milled heads etc.
This truck is totally stock with felpro gaskets and 243 heads. How come such a long pushrod length? With correct preload says we need 7.500 but I can't believe tht with this setup. Not the norm for me. Thoughts?
Old May 6, 2026 | 03:45 PM
Full Power's Avatar
"we measured and preload etc comes out at .050""
A Measured value always trumps Internet advice.
Old May 6, 2026 | 03:56 PM
brandon6.0's Avatar
I agree but this measurement is not normal in LS stuff I have built. How come such a longer pushrod length needed? Smaller base circle cam?
Old May 6, 2026 | 06:02 PM
RB04Av's Avatar
Maybe because that's the length you need.
​​​​​​​It Is What It Is.
Old May 6, 2026 | 06:28 PM
brandon6.0's Avatar
Well finally got a new mic to check length with. I come up with 7.300" measuring the checker. Add .100" equals 7.400"
For some reason my checker isn't reading a true .50" with each turn out. I have always measured using a mic but my old mic had broke so I used the each turn =.050" method this go around.but apparently thts not accurate. At least with this checker.
Makes since to why it's reading long.
Old May 7, 2026 | 06:38 AM
Kubs's Avatar
Never trust the turns on a checker. Always measure.
