Info And Part #'s For The Ls2
Old Jan 25, 2005 | 10:07 AM
MrDude_1's Avatar
ttt
while you're posting LS2 part numbers, do you happen to know the # for the fuel rail covers?
after ALOT of searching, ive found they arnt posted on this board, LS2.com, or anywhere i found thru google.
Old Jan 25, 2005 | 03:43 PM
crow2's Avatar
Originally Posted by MrDude_1
ttt
Heywe keep these LS2 fuel rails in stock! Pm me and i can let you know how much!
thanks
Old Jan 25, 2005 | 04:27 PM
MrDude_1's Avatar
the COVERS not the fuel rails.
Old Jan 31, 2005 | 10:23 PM
KJ's Avatar
KJ
The LS2 fuel rail covers are not listed in the GM catalog yet. I will try to get in touch with a GM rep. and see if I can get it.
Old Feb 1, 2005 | 12:12 PM
MrDude_1's Avatar
12569246 passenger side intake manifold sight shield.
12568998 driver side intake manifold sight shield.
found them!
Old May 21, 2005 | 11:36 PM
redaddiction's Avatar
Has anyone gotten the part number for the block yet ?
Old May 22, 2005 | 10:36 AM
ACW's Avatar
ACW
Apparently it's 12568950 (have also seen 12589485 said)
Old May 25, 2005 | 05:25 PM
KJ's Avatar
KJ
12568950 is correct, and we have them in stock!!
Old May 25, 2005 | 08:56 PM
Thanks guys either one of those work.
Old May 31, 2005 | 03:06 AM
Colin GD427's Avatar
Hi Kris
I am going to rebuild my LS6. Is it right the LS2 oil pump is a better pump because of its higher capicity? If so do you have in stock, how much, and part Number.
Regards
Colin
Old Jul 31, 2005 | 12:37 PM
Jeff Smith's Avatar
I did try to do search on Goggles.com and even GMGoodwrench for the LS1 Block cast# and can't find solve. I got have LS1 Block cast # 12559378 (it stamped on back of the drive side). Curious what kind of vehicle it come from ? 2002 year?
Cylinder head #241>>> Curious what kind of vehicle it come from ? 2002 year?
Please help me....
Old Oct 26, 2005 | 04:01 PM
  #32
Jeff Smith's Avatar
Is that #125688952 block related to LS2?
I have T56 6 speed manual (Former 2001 LS1) and plan attach to LS-2 block and put it on my 2002 Camaro.
My questions is:
1) Can use Camaro Flywheel and Clutch (former 2001 LS1)?
2) Can use Camaro Starter?
Thanks
Old Oct 26, 2005 | 08:25 PM
  #33
ACW's Avatar
ACW
12559378 is a 5.7L LS1 block from 1999-2000, possibly early 2001.
From https://ls1tech.com/forums/showpost....36&postcount=8 :
"The 1999-03 LS1’s [cylinder heads] have casting number 241"
12568952 (you had an extra 8 in there) appears to be a 6.0L LS2 block used in the 2005 Cadillac CTS-V.
Old Nov 29, 2005 | 12:24 PM
  #34
Builder's Avatar
Default Part Numbers - LS7 Engine (Injector - Fuel Rail) Covers
LS7 Engine Covers - These are the red covers that snap onto the top of the engine. If you can't get the pair for $70, drop me a line.
12574619
12574620
Old Dec 30, 2005 | 05:14 PM
  #35
poloz28's Avatar
how bout prices and part numbers for power steering pump pully and crank pully? are they the same as old 00 corvette setup?
Old Dec 30, 2005 | 05:32 PM
  #36
Katech_Jason's Avatar
LS1TECH Sponsor
Well, since we're digging up this old thread I thought I should post the solutions to a couple of the problems listed here.
FUEL INJECTOR PROBLEM:
We have a spacer kit that allows you to use the LS1 fuel rail and injectors on the LS2 manifold. It includes bolts, billet aluminum clearcoated spacers and o-rings (2 extra).
$39.39
THROTTLE BODY WIRING PROBLEM:
We have an adapter harness that allows you to plug-and-play a LS2 throttle body into the LS1/LS6 drive by wire car.
$50.00
CAM SENSOR / KNOCK SENSOR WIRING PROBLEM:
Most people know by now that you can extend your harnesses and route the knock sensors to the side of the block behind the motor mounts. We are working on a quality harness that allows you to do this plug-and-play with no cutting. It will be ready very soon
$TBD
MAP SENSOR WIRING PROBLEM:
We are also developing an extension harness for the MAP sensor so that you don't have to cut your wires there either.
$TBD
Old Jan 4, 2006 | 10:46 AM
  #37
LS1TECH Sponsor
Update the other (part number list) thread.
2006 LS2 Crate engine 19156261
The 2005 has been discontinued.
Old Jan 18, 2006 | 01:22 PM
  #38
Neill's Avatar
Does that imply that the aerlier 12499750 item is the 24x reluctor wheel and the later 2006 pt number 19156261 has the 58X wheel?
Thanks
Neill in the UK
Old Jan 22, 2006 | 04:00 PM
  #39
UMIRacing's Avatar
That is correct on the reluctors. Besides the part number, the only other way to tell which engine you have is the color of the crank sensor. The 24x has a black sensor, and the 58x has a grey sensor. Keep this in mind when you are ordering any engine managment systems such as our calibratable MEFI controller.
I have already had to play the send your stuff back so it can be modified game. Suppliers, be sure to ask them which one they have so you don't have to do any more work than necessary!!!
Old Apr 18, 2006 | 12:19 PM
  #40
NemeSS's Avatar
Default request part numbers
part number for the ls1/ls2/lq9 2.00 intake valves (stock)
and 1.55 exhaust (stock) valves
