How to wire drive by wire to pcm on ls2 TB?
http://forums.corvetteforum.com/showthread.php?t=883429
We know that much, i think he is asking if u put a drive by wire TB on an F-body......we know that you can wire it up to the PCM, but how does the acutal pedal, that is setup to be cable operated, actually control the opening and closing of the TB without any physical connection being present anymore?
We know that you can wire the TB to the PCM so that the TPS will work properly, but how does the pedal connect to the TB now that there is no cable and the f-body does not have "the equivalaet" of a TPS on the pedal?
