Stupid stupid oil question
When you change the oil, when do you check the level.
Immediately
or
Run the car and check it
or
run the car, let it sit for a few minutes and then check
I should really know this, but I always forget
Immediately
or
or
make sure u let it run long enough for the oil pressure to build up and then shut it off, you should beable to walk to the front of the car then and check the oil. unless u have crud in the engine and its not draining back down well it will read right after sitting for about 30 sec
