427 Heads (C5R vs. LS7)
Then I heard about the LS1 so I bought the 02 SS.
I think I will be selling the 89 IROC in the next year to offset the cost of the LS7 and other mods I'm doing to the 02
The 89 has only 26000KM on it so I should get some good cash for it
I see yours has been sitting for a while too?
http://www.gearchatter.com/viewtopic11203.php
My point is that if the LS7 heads flow 360 or 348 or whatever at .600 it will be fine for street use IMO. Any port work will increase the size of the port volume and a few extra CFM at higher lift will not likely benefit any cam most of us will be using on the street. There will likely be much potential for those those willing to run a solid cam and over .700 lift I have no doubt.
I also have no doubt that after a few years of R+D maybe porting shops will be able to improve the mid lift #'s on these heads (maybe unfinished as cast heads will be available from GM?). Till then I will be bolting a set of them on my 427 as I get them from GM since I'm pretty sure they will work quite fine
That is just not right to make us drool like that.
<----Truck Director
There is a new truck head coming out that looks killer also.
New truck head huh. Similar to the LS7 or the LS1?
Is very similar to the ls7 head. Raised runner etc. I think it will be out on a larger ci truck engine. If my source is right
s for C5R heads to compare?
Sounds great! I wish you the best of luck with that.
Mines still sitting. It is way overdue for an engine swap. If things with me and work out good, then I just might. : )
