Cam Sensor
Old Apr 1, 2005 | 01:47 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Default Cam Sensor
Hey Guys, Wanted to run something by you. I'm tuning an LS2 stroker, ET heads, fast intake/TB, 38lbs, and a 238 or so cam on an engine dyno.
The cam sensor is obviously up front. I'm using an '02 camaro pcm to tune it up. The harness is an aftermarket ls1 harness, with the cam sensor wire extended just enough to fit the front.
I keep getting a cam sensor ses code coming up, I believe it's the 336 code.
Will this cause any problems?
How are you guys solving this issue if it's common.
btw, i did the search and couldn't find a good answer.
Also, any guesses on how much power it's making?
thanks in advance,
allen
Old Apr 1, 2005 | 06:46 AM
Project GatTagO's Avatar
I remember something about 2 wires that needed to be flipped on the crank sensor in order for it to be compatible with the LS1 ECU.
Andrew
Old Apr 1, 2005 | 09:46 AM
DrkPhx's Avatar
The Crank sensor is fine, it's the cam sensor that needs the left and right wires switched by splicing them.
Old Apr 3, 2005 | 11:53 PM
pkincy's Avatar
Buried in the original LS2 402 thread is the instruction to keep the center wire on the cam sensor in that position and reverse the left and right leads. We did this and it is working great....No ses light (except when it is reading the natural missfires of a cammed engine.).
Perry
