Anyone heard of LS3? Flow #'s inside
Old Apr 5, 2005 | 11:28 AM
NOSjohn's Avatar
Restricted User
Originally Posted by BurnOut
I think that's the LS4, though I could be wrong.
I've heard the same thing...speculation is LS4. An LS3?
Old Apr 5, 2005 | 04:43 PM
dhdenney's Avatar
Do we have some production dates on any of the latest LSx heads? I myself would like to do an LS project and am very curious about the LS7 heads and when they're gonna hit the shelves.
Old Apr 5, 2005 | 05:52 PM
SmaknaSS's Avatar
Originally Posted by Brian Tooley
Ooops, my bad, 400 @ .900", that's what happens when you try to go off of 40 year old memory.
.1 68
.2 139
.3 217
.4 282
.5 337
.6 358
.7 373
.8 385
.9 400
For those of you that pay attention to .500" flow numbers, 337 is STOUT for as little work as we have put in these heads. LS7 flow numbers coming soon, as long as, you know
Old Apr 5, 2005 | 06:29 PM
Wnts2Go10O's Avatar
it is an ls4, maybe its justa typo?
Old Apr 5, 2005 | 07:22 PM
AdioSS's Avatar
The LS3 was probably the motor used in the concept orange GTO and blue Colorado that GM let out for the WoodWard Dream Cruise...
I know of at least one LS1 motor that could definitely use a set of LS7 heads that flow 400cfm@800-900 I also know of a company that would love to have a set of 5.3L heads that flow 330ish cfm...
Old Apr 5, 2005 | 08:13 PM
amwellls1's Avatar
wow, nice numbers, need to know more
Old Apr 5, 2005 | 08:27 PM
Wnts2Go10O's Avatar
those were ls2's
Old Apr 5, 2005 | 09:10 PM
CamTom12's Avatar
Originally Posted by ChucksZ06
I can not wait until this stuff becomes available. Huge horsepower will be easier than ever. I get so sick of hearing about low rpm flow...what is your transmission for anyway? If you make sick hp from 4,000 to 7,000 who gives a rats rear end if you are down 50 ft lbs at lower rpms. Some good tuning will make the car nicely drivable at lower engine speeds. When I want to go I downshift and GO. A lot of this talk of low speed flow numbers comes from those who are stuck in the carburator era.
The question was about low-lift flow. Your valves are partially open for way longer then they are at peak-lift so those numbers are very important to making power. Doesn't have too much to do with engine speed
And these low-lift numbers are very stout
Old Apr 5, 2005 | 11:16 PM
JZ'sTA's Avatar
A 2.20 valve is huge.
The heads were also flowed on a 4.125 bore, however I bet for stock castings they would still work nicely on a 4" bore with a 2.08 valve.
Old Apr 5, 2005 | 11:26 PM
BrentB@TEA's Avatar
we wanted them to compare with the ls7 stuff They take a very large valve stock, They also may be for a larger bore
Old Apr 6, 2005 | 07:50 AM
Project GatTagO's Avatar
Originally Posted by 8KickassRS9
those were ls2's
The engine in the Colorado pickup was an LS2, but the engine in the orange GTO is definitely NOT an LS2. I believe it was an LS7, since the manifold was definitely the LS7 design and the head casting number was 8452, which I do believe is the LS7 head.
Andrew
Old Apr 6, 2005 | 09:10 AM
  #32
BBQLS1's Avatar
Correct
Old Apr 6, 2005 | 10:49 AM
  #33
dhdenney's Avatar
WHEN'S THIS STUFF HITTING THE SHELVES? BALLPARK IS FINE.
Old Apr 6, 2005 | 12:15 PM
  #34
Big-DEN's Avatar
When tooley get into the LS7 head my prediction is at or near 300@.4", 350CFM@.5"
and 400CFM will be achieved at .700" lift. If exaust side even gets to 250@ around .600"
things will be great.
Now how does that intake do, and can someone discuss runner flow and length.
