AFR 225 on LS2
Old Jun 1, 2005 | 07:39 PM
04Yukonxl's Avatar
Default AFR 225 on LS2
Anyone run AFR 225s on a stock cubed LS2? Wondering if you can maintain decent low end with these heads. Port size is slightly larger than stock LS6, but certainly quite a bit smaller than most ported heads.
Old Jun 1, 2005 | 08:12 PM
Beast96Z's Avatar
The port may be a bit larger, but the flow is higher also. This means more velocity. More velocity= more power. I couldn't see anything but gains in the lower rpm's with the AFR's.
