Stroker Cam spec
Old Jun 6, 2005 | 11:42 PM
2002gt's Avatar
Default Stroker Cam spec
Hey all you 402 ls2 stroker guys out there.
What is a good cam to run in a 402 stroker. I need your help.
I want to make a good street/strip car, that is streetable but makes good power. Hoping for 500rwhp/500 rwtq.
I was thing of the MTI Z1 cam 236/236 .585/.585 ,112 lsa At.50"
Do you guys think its too small. Any Ideas???
Any sound clips of cars idling would also be great.
I am building a 402 stroker with the following.
Fast 90/90
Stage 3 heads int 330/ ext 230
ls2 402 short block with eagle rotating ***
11:1 comp
Thanks 2002gt
Old Jun 7, 2005 | 12:31 AM
ZLEEPER's Avatar
at what lift do your heads flow 330 cfm? If it's at .600 or better, then you'll need a cam that has a lift of at least .600. 236/236 .585 .585 seems like it would run well but you definately could go bigger with the parts your using.
chris
Old Jun 7, 2005 | 01:20 AM
DietCoke's Avatar
Get a cam custom ground to your heads and motor.
Old Jun 7, 2005 | 09:17 AM
DrkPhx's Avatar
Agreed. I bought mine from Mike at Rapid Motorsports. He has done a few cams for the LS2 402's. Give him a call.
Old Jun 7, 2005 | 10:33 AM
Cyborg's Avatar
Yeah I'd say go bigger and consult with a cam specialist about your particular goals and setup
Old Jun 7, 2005 | 10:46 AM
89FormulaLS2's Avatar
Kris Jones had Crane grind a custom cam for my LS2 and heads setup.
Old Jun 7, 2005 | 08:31 PM
GORDON's Avatar
I have the TSP ms3 237/242-603/609-113 in mine very satisfied..
Old Jun 7, 2005 | 09:57 PM
2002gt's Avatar
Any guys want to list some specs and horsepower numbers.
 Michael S. Palmer
