Oil pressure question
Old Jul 7, 2005 | 12:32 PM
jyeager's Avatar
Default Oil pressure question
A friend has an '05 GTO with the LS2 (obviously). He just had heads/cam installed and has a new ticking noise seeming to come from the top of the engine somewhere.
My first thought was that the typical oil-pump-o-ring mistake may have been made lowering the oil pressure.
The problem is that there is no oil pressure gauge on these cars and no generally available software yet that reads the PCM, so it's not easy for him to verify his oil pressure.
What's the best way to read the oil pressure? Is there an available plug to be removed for a mechanical gauge or should he read resistance across the sender? (where is the sender located?)
Any other suggestions as to what the ticking might be? I've been told that the mechanic rechecked the pushrod length and rocker arm adjustment.
He had some form of Patriot heads and an MTI Stealth Cam installed but I'm not sure of specifics.
Thanks.
Old Jul 7, 2005 | 12:48 PM
Fade2blk500's Avatar
How loud is the ticking? What size is the cam? Big cams are known for some excessive valvetrain noise.
Old Jul 7, 2005 | 12:52 PM
jyeager's Avatar
Big in lift, duration, or aggressive ramp rate? It's the MTI Stealth II cam. So the duration is in the 220 range. Lift is bigger, but not what people usually call big, and I believe the ramp rate is more aggressive.
I haven't heard the ticking yet, only talked to him about it.
Perhaps it's a benign ticking, but it would be nice to have a double check on the oil pressure just to be sure.
Old Jul 8, 2005 | 01:18 AM
I would definitely check the pressure. I'm sure a good bit of that ticking is from the valvetrain and is probably normal.
Old Jul 8, 2005 | 06:09 AM
jyeager's Avatar
Thanks for the comments guys.
So does anyone have any recommendations on how best to read the oil pressure on this thing?
Old Jul 17, 2005 | 11:00 AM
jimmyp's Avatar
do the ls2s have the spot above the oil filter to tap into the oil pressure?
