LS7 Intake
Old Sep 13, 2005 | 02:05 PM
52172's Avatar
Default LS7 Intake
Will a NW 90mm tb fit the ls7 intake so we can run ls7 heads and intake on a resleeved ls1 block in an F bod?
Old Sep 13, 2005 | 02:42 PM
NOSjohn's Avatar
Restricted User
LS7 heads are indexed to larger bores and can not be used on bores smaller than 4.060. So, unless your bore is that size, getting the intake and heads will be useless.
Old Sep 13, 2005 | 02:44 PM
98_Formula's Avatar
if you have a bore size say like 4.1, what kinda gains could you expect to see with the ls7 intake and heads... ne1 have an idea?
Old Sep 13, 2005 | 02:49 PM
Nick Williams's Avatar
The LS7 uses the LS2 TB bolt pattern which is compatible with my TB or a FAST TB. You just don't use the top hole.
Old Sep 13, 2005 | 02:55 PM
NOSjohn's Avatar
Restricted User
I don't think anyone has one to test...
Old Sep 13, 2005 | 02:59 PM
matt346ls1's Avatar
I have an LS7 Manifold. 3 piece composite.
Old Sep 14, 2005 | 03:25 AM
52172's Avatar
I know I know read the post I state resleeved ls1 block that means large bore. I plan on getting the 4.200 MID sleeves and building a 401 all bore motor with ls7 heads and intake want to know if the NW 90mm tb will fit an ls7 intake to use on a f bod.
