LS2 valve springs + boost?
on this.Oh well, I guess it's just two guys with different views debating on the internet, lol. I would like to see some FI guy use stock ls6 springs @ 10 lbs, then change nothing else except to a dual spring package. Dyno each, and look for changes. Anyone have an engine they wanna risk? hehe.
Also your above statement about back to back dynoing wouldn't nescesarily be a valid test for valve float caused by boost (although it will tell you if you create more power). The only way to test it would be with a high speed camera (spintron).
Think of it this way - blow with your mouth onto a straw, and put your finger over it. You feel some resistance. Now blow harder - takes more force to close off the straw right? A valve spring will have an harder time closing a valve under boost as opposed to normally aspirated.
I guess the overall point of this whole conversation would be to run the proper springs for the cam you are running. Granted you could take a forced induction engine change the springs and pick up power. There is however no gurantee that valve float would not occur with the same cam profile in a non forced induction application. You would have to watch it with a high speed camera. A forced induction car would be extremely sensitive to floating valves where you might not notice it as much on a naturally aspirated car.
I am hunting around the internet right now for a site I stumbled across a few years ago. It was a site for an engineering college at a major university, that had some great java apps for doing volume calculations for every degree of crankshaft rotation. It may do a better job of explaining it than I have, thus far.
I can assure you that in regular production engines, the charge is still rushing in (due to momentum) as the piston is already moving up on the compression stroke. This is regardless of whether the intake on that particular engine is tuned or not. This is why the intake valve is shut after BDC not before.
I'm not trying to be a flamer or anything, Comp, I'll try to find some actual research to back up my theory too
Same as the 2002-04 LS6 cylinder head, no changes on the bare head. However the LS2 engine uses the stock LS1 valves rather than the lightweight Z06 valves.
this is cut from scoggin's post on ls2 parts, so are they 01's or 02's, who's right/wrong?
