65lb inj for LS2 fuel rails
Old Sep 17, 2005 | 09:08 AM
greentahoe's Avatar
Default 65lb inj for LS2 fuel rails
Where can I find 65lb inj that will mate up with the LS2 fuel rails? What kind of modifications are req to make them fit? Im using an LS2 manifold as well.
Old Sep 17, 2005 | 06:34 PM
red90cobra's Avatar
https://ls1tech.com/forums/lsx-parts-sale/381348-phamspeed-manifold-kit-much-more.html
i would buy the motron 60# injectors.
Old Sep 17, 2005 | 06:38 PM
red90cobra's Avatar
should be able to run the injectors no problem just need the lower o rings. as far as installing them on the rail they slide right in well the aftermarket ones did. make sure you use some lube so it doesn't tear the o ring up.
Old Sep 17, 2005 | 11:14 PM
greentahoe's Avatar
thanks man!
Old Sep 17, 2005 | 11:55 PM
red90cobra's Avatar
thanks man!
no problem
Old Sep 22, 2005 | 02:32 PM
MTBDOC's Avatar
Just did this to go along w/ my turbo. I used the Mototron 60's. Katech has a little kit with spacers and longer bolts, + the necessary O-rings for the injectors. Oh...it just occurs to me that you don't have a factory LS2 engine w/ rails, etc...my bad!
Yeah, just the O-rings. I needed spacers, and wiring adapters, as the LS2 not only uses 'shorty' injectors, but the plug is different. The same adapters that the cobra guys use worked.
