LS2 with LS1 accessories
The holes that are drilled into the heads look identical. Are the mounting bosses on the block also the same?
It's far easier to fit an LS1 water pump and F body balancer than to move every other pulley and bracket.
You will have to fit an F body oilpan and stuff as well.
