which LS1 components are interchangeable on LS2 short block?
My questions is:
1) Can use Camaro Flywheel and Clutch (former 2001 LS1)?
2) Can use Camaro Starter onto LS2 motor?
Thanks
knock sensor will not get in the way of the headers depending where you put them. (there is a hole in the block near the rear of the block) i also wrap my sensors with the heat wrap.
you will need the lifter trays for the ls2
one side of the block will need to be shaved to fit the motor mount
you need to put washers on the windage tray because to crackshaft bolt will
not clear (this is for the 402)
headbolts will need to be changed
you need to get the cam sensor wire (racetronices)
timing chain and cover, valley cover, will be needed unless you buy from sdpc (they will give this to you )
thats about it. you might want to change your oil sensor while you engine is out. mine went out a week after the install and it took about 2 the change it. it only 40 bucks.
good luck
as for heads i have heard the afr 225 are very good but $$$$$ i also heard that the patriot heads are the best bang for the buck at 1,300
