does ls2 conversion require ls1 ecu
Old Nov 4, 2005 | 08:59 AM
shanekennedy's Avatar
Default does ls2 conversion require ls1 ecu
looking @ used ls2 to install in 68 camaro. can i send off ecu/harness for mods, or do i need to buy ls1 ecu/harness to get it going.
Old Nov 4, 2005 | 11:53 AM
DrkPhx's Avatar
It's actually called PCM, not ECU. You will need a LS2-specific PCM to run a stock LS2 because of certain sensors, most inportantly the crankshaft position sensor.
Old Nov 4, 2005 | 12:29 PM
KJ's Avatar
KJ
It would be best to use the LS2 PCM if you can. Are you getting the harness with the engine? The harness will help make the decision on what PCM to use.
If you are getting the engine only, we can get you a complete harness and stand alone PCM.
