LS7 Ancillary Components
Old Nov 14, 2005 | 01:11 PM
org's Avatar
org
That's normal for dry sump systems, since there shouldn't be any oil to amount to anything in the pan. No idea why there's a cap on the valve cover at all.
Old Nov 14, 2005 | 01:18 PM
98blackSS's Avatar
Unless they're leftovers from the LS2 which use it?
Old Nov 14, 2005 | 02:22 PM
org's Avatar
org
Dry sump systems are generally filled at the tank...there shouldn't be much oil in the sump at all, so if the tank is full, it's good to go. If the tank is empty, it's a good idea to check that it didn't just leak into the engine.
Cranking should scavenge the oil into the tank in that case so you can measure it.
