what changes needed to install LS2 block into a 2000 LS1 camaro?
Old Nov 17, 2005 | 06:51 AM
Abdullah's Avatar
Default what changes needed to install LS2 block into a 2000 LS1 camaro?
what changes?
i read that i nead to swtich the cam sensor wires? i think i read that there is a special wire connector to do this.
also what about the knock sensor? what i have to do about them.
is there any thing else?
thanks.
Old Nov 17, 2005 | 07:26 AM
PREDATOR-Z's Avatar
SDPC has a harness kit to do that swap. It is pretty much straight forward.
They also have 402 LS2 shortblock kit and a crate LS2 kit.
Old Nov 17, 2005 | 08:25 AM
KJ's Avatar
KJ
Thanks Predator-Z!! He is correct, we do have the cam and knock sensor extentions that are "Plug & "Play". Please pm, or email me with any questions you might have!!
Old Nov 17, 2005 | 09:17 AM
Abdullah's Avatar
KJ, what is the max over bore possible in a LS2 block? i read the max over bore you can go with an LS2 block is 4.020". can't i go with 4.030" or problems might happen?
Old Nov 17, 2005 | 11:47 AM
KJ's Avatar
KJ
I just sent you an email. 4.020 is what GM says you can bore to. If you should want to go to 4.030 bore I would sonic test it before you do. It might be ok, but the sonic test would be cheap insurance!!
