best LS2 intake manifold??
I've ready the LS2 intake actually flows worse than the LS6. Also, I know the FAST intake is an option.
bottom line, is it worth the trouble of porting the LS2 intake, or switching to the LS6 intake, or buying the FAST. If you port, what part do you port???
Thanks
I tried all 3 as you may remember. The LS2 was a dud. The Fast/LS2 was fine, well the manifold is kinda a pain, but in the end no more dyno power so back to LS6/Shaner. Seeing more non results with Fast/90 on non agressive cammed stock disp motors. A&A claims the Fast is better on a LS2, if you are talking about your C6, but is it better than LS6?
See5: thanks, I knew someone had posted about this, but couldn't track it down.
no they wont 78mm vs 90mm also different mounting positions for fuel rails and different injector spacing.
