Good info on the LS7 intake...
http://www.corvettels7.com/06_PWT_LS7.pdf
Low restriction intake and ported cylinder heads
A new low restriction intake system is used, with approximately 20 percent less restriction than the intake in the 6.0L V-8. A new drop-in mass airflow sensor minimizes flow restriction. The intake manifold is a new 3-piece friction welded port-matched composite unit. The large straight intake runners are designed to maintain fast airflow velocity, while air volume increases 18 percent over the 6.0L V-8. The filter element is supplied by Donaldson Company, Inc., known for high-performance and racing filters.
20% less restriction and 18% more volume. not bad
Intake mani's are basically tubes or pipes, so unless there is some kinks or kneck downs in the system one can assume that larger cross section equal larger flow.
No one still has given us LS7 intake numbers flow without heads attached and
LS7 head/intake numbers with intake mani attached at valve lifts from .200" to .800".
My guess has always been that with intake bolted to the heads, that flow is 325CFM.
That the mani by itself flows closer to 350CFM. No one has confirmed this yet.
Fast 90 with heads attached has always shown to be under a 300CFM affair when bolted to cyllinder heads.
We need someone to confirm this for us.
