LS2 and cable throttle body
Old Dec 20, 2005 | 02:30 PM
Neill's Avatar
Default LS2 and cable throttle body
A quick question to all of the learned ones: Is there any standard GM cable throttle body that fits the Vette LS2 plastic manifold/plenum in place of the OE fit 90mm electronic throttle body?
Has anyone taken the electronic one apart and adapted it to cable operation, once I get the right sized tamper proof 5 point bit I will take it aparts to see!
Thanks for your help
Neill
United Kingdom
Old Dec 22, 2005 | 11:34 AM
Nasty N8's Avatar
None from GM. Aftermarket TB is the way to get 90mm on that intake. Nick Williams and such.
Nate
Old Dec 24, 2005 | 02:03 PM
Neill's Avatar
Thanks
May take the electronic one apart, even though I understand that this destroys some vacuum sealing process and it is liable then to be useless!
Worth a look I think, will let you know if it is possible to adapt to cable operation.
Neill
