ls7 info in Hot Rod article
Old Dec 23, 2005 | 06:42 PM
ChucksZ06's Avatar
Default ls7 info in Hot Rod article
Magazines are notorious for getting specs wrong...but for the sake of discussion I am assuming they had them right. The intake to exhaust ratio is much higher on the intake side than the ls6 heads. I noticed that the factory cam has 19 degrees more on the exhaust side. The largest cam that really seemed to wake up the engine had 43 degrees more exhaust timing than intake. Does this necessarily mean that there will be power to be found in working on the exhaust side? Seems like a pretty large split. What do you guys say?
Old Dec 24, 2005 | 12:55 PM
digitalsolo's Avatar
If that data is accurate, it needs some serious exhaust work. Don't forget the LS7 heads behave differently, flow wise, then previous LSx, though.
