What are the differences in the LS1, LS2, and the LS6?
Old Jan 5, 2006 | 05:35 PM
Stampede4ever's Avatar
Default What are the differences in the LS1, LS2, and the LS6?
Heads, intakes, flow numbers, cubic inches?
Thanks.
Old Jan 5, 2006 | 05:55 PM
niphilli's Avatar
Thanks.
LS1 = 346CI LS1 casting heads
LS6 = an evolution of the LS1 better flowing heads (243 castings), bigger camshaft, better intake manifold, still 346CI.
LS2 = an evolution of the LS6with a 4" bore (6.0L (364CI?) VS 5.7L for the LS1), Two piece intake manifold that looks to be a step backward from the LS6 manifold. Same 243 casting LS6 heads.
Basically the internalls of all of these motors are the same architecture with slight upgrades over the years.
Old Jan 5, 2006 | 07:08 PM
Thanks, I thought the LS6 was the 6.0L.
I have one more question, does the cam have the same distance from the crank up?
And can you put an LS6 intake on a LS2, what would the results be?
Thanks again.
Old Jan 6, 2006 | 10:13 AM
niphilli's Avatar
It would seem to logic that the LS6 was the 6 L, but the LS6 came before the LS2 back in the 346 days (2001).
The LS1,2, & 6 all use the same timing chain so I feel pretty safe to say that the cam is the same distance from the crank.
I think the fuel rail/ injectors are different on the LS2 VS the LS6. You can put an LS6 intake manifold on an LS2 but it takes some modification. I think the guys over at gear chatter did a swap like this and picked up between 5 & 10 HP.
