Stock LS7 on engine dyno with BS3
Kurt
Bill
The factory rated 505 is SAE J-1349 (29.23" Hg and 77F) corrected, which most people refer to as SAE corrected. Kurt's numbers are SAE J-609 (29.92" Hg and 60F) which is referred to as STP corrected. The difference is about 3.8%, STP being higher. This makes the peak HP 527hp J-1349 or SAE corrected.
So...22hp gain with headers, dyno exhaust, and calibrations sounds about right.
and he only has a little 377!
Chris.
).Unfortunately, I can't make a record attempt. The 9.8 second record for 0-100-0 is for a car as available from the factory. I could only go for it if Ultima would start offering the LS7 and G50/52 combination for the GTR.
That's not to say I won't be working on beating it anyway.
I have to say that if I was to do a Canam ( which I am think about ) I would use an LS7, a motec m800 , fly by wire throttle, traction control.
I think this project is as important to the Ultima brand as my 377ci was ....
It really has to be the new engine of choice .. issues would be the the exhaust manifold and catalyst convertors that a new engine would require in the UK and Euroland. But considering it has the head designed by Chapman who did my head, Ti rods and valves it has the right parts for $14K (£8K) is unbelieveable
You would in my opinion have to run the reverie carbon side pods with a cold air feed to the throttle body
And yea, I'm Scott's friend doing a twin turbo LS2 with a pair of Turbonetics T61's
Jeff S
www.schwartzperformance.com
Didn't catch your post earlier. Thanks!
Do you think it will be competitive in the quarter? I hope to run mid-10s at ~140.
In final runs, we fell just short of 560hp with the FAST TB upside down on a spacer. After installing the UMI tb upside down with the spacer, we made 564hp@6000 rpm. The UMI seems to drive up smoother on the transition from idle.
Thanks Scott(Builder) for sending your LS7 to be used in the test, I will be the one crying when it ships out......
Kurt
I can understand your tears, Kurt. Take comfort in knowing that it will be tears of joy at my end. You guys have accelerated my build in more ways than one and I am truly grateful.
564!!! Ohhhh, yeah baby!!!
Do you think that the UMI throttle body is worth the price???
How did it compare to the FAST unit by quality standards?? Is the throttle as cheesy as the FAST or not. I think we are all waiting to see what you have to say about this new throttle body.
Kurt
