LS2 conversion questions (LS1--->LS2)
Old Jan 19, 2006 | 07:12 AM
rao's Avatar
rao
Default LS2 conversion questions (LS1--->LS2)
I searched around and called around and I can't find definitive answers to the following questions:
1. If you relocate the kock sensors from the valley (LS1) to the sides of the block (LS2), can the LS1 computer still use them? I know you can wire them up, what I don't know is if they will still work.
2. The 2006+ :S2 blocks use a 58 tooth reluctor wheel on the crankshaft and the LS1 computer is expecting 24 teeth - any way to solve this?
Thanks for any help or direction where to find the answers.
If this has been covered I apologize in advance.
Old Jan 19, 2006 | 07:21 AM
spy2520's Avatar
i think people have been swapping reluctor rings on the crank...could be wrong.
Old Jan 19, 2006 | 07:36 AM
Katech_Jason's Avatar
LS1TECH Sponsor
1. yes
2. spy2520 is right or wait for HP tuners (hopefully soon)
Old Jan 19, 2006 | 08:49 AM
rao's Avatar
rao
Originally Posted by Katech
1. yes
Thank you. I just ordered some of your rod bolts.
Swapping the reluctor makes a rebuild of my ls1 block (or the use of a truck block or the use of a blower) more appealing.
Old Jul 28, 2006 | 05:18 PM
1dirtyZ's Avatar
sorry for bringing this thread up from the dead , but is there an update regarding this ??
do you still have to swap the reluctor wheel? did hptuners fix this?
Old Jul 30, 2006 | 04:11 PM
LS1TECH Sponsor
You have to swap the reluctor.
