Injector O-Rings
Old Jan 22, 2006 | 05:29 PM
proautoman's Avatar
Default Injector O-Rings
Are there bigger injector O-rings so you can utilize on an LS2 or LS7 Intake
with earlier Injector design. I know the holes are bigger on LS2/LS7 Intakes.
39# Injectors(Bosch) from Ford Motorsports are way cheaper than stock LS7
injectors and the electrical connector is the same - but I believe they
are smaller where they go into the intake manifold Larger O-Ring MAybe
Anyone????
Old Jan 22, 2006 | 05:43 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Anyone????
$39.39
Old Jan 24, 2006 | 04:57 PM
jpolser's Avatar
Have you noticed problems with the o-rings fitting loosely? It would seem that when the rail is bolted down everything should seal, but they do fit more loosely (ls2 o-rings) on the svo-style injectors than the factory ls2 injector.
