Can an LS7 intake be reversed?
Old Jan 25, 2006 | 01:22 PM
DavidNJ's Avatar
Default Can an LS7 intake be reversed?
In some mid-engine situations, the intake needs to be reversed with the TB over the bellhousing.
Is this possible with an LS7?
Thanks,
David
Old Jan 25, 2006 | 01:37 PM
UMIRacing's Avatar
The problem you will run into is the oil pressure sending unit will be in the way. Other than that, yep
Old Jan 25, 2006 | 01:55 PM
DavidNJ's Avatar
Is that a fixable problem? Can it be tapped in somewhere else? Does the main galley have any external plugs?
Old Jan 25, 2006 | 02:15 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
Yes you can. Here is an example on our dyno for a mid engine application.
We cut part of stantion for the sending unit for clearance tapped it 3/8 pipe, plugged it, and the sending unit will go in the side of the block.
Old Jan 25, 2006 | 02:25 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Thanks,
David
Alright! I see your considering an LS7-powered GTM. David, give me a call or email. We have crate engines and pistons in stock.
Old Jan 25, 2006 | 04:38 PM
98blackSS's Avatar
Kurt, is that Scott's motor? Looks good
