Will the '05 computer work with an '06 LS2?
Old Feb 6, 2006 | 02:01 PM
stick's Avatar
Default Will the '05 computer work with an '06 LS2?
I'm new to the forum and just bought an '06 LS2 Corvette engine for installation in a '55 Chevy. I've been told that the '05 computer will work in the '06 engine. I know the reluctor is different and thought I should check to see if anyone knows if the '05 computer will work.
Old Feb 6, 2006 | 05:45 PM
See5's Avatar
Careful-- I think the 06 has the 2x crank sensor like the LS7.
Old Feb 6, 2006 | 07:20 PM
Steve1969LS1's Avatar
Originally Posted by xphantomws6x
I'm pretty positive the 05 and 06 PCM's are identical. The 05 and 06 LS2's are identical, so I don't see why the PCM's would be different.
Buzz.. wrong answer..
'05 LS2 has a 24x reluctor and table based programming
'06 LS2 has a 58x reluctor and math based programming
Old Feb 6, 2006 | 07:51 PM
x phantom x's Avatar
STF veteran / 10 second club
Ahhhh that's right. I stand corrected.
Old Feb 7, 2006 | 12:56 PM
stick's Avatar
[QUOTE=Steve1969LS1]Buzz.. wrong answer..
Thanks, Steve, that's what I was afraid of...
Old Feb 10, 2006 | 12:03 PM
stick's Avatar
For anyone who has this same problem, the wiring harness for the 2006 LS2 is being completed by FAST and they anticipate it to be one to two months out...
Old Feb 10, 2006 | 01:45 PM
TPiS's Avatar
Tenured Member
if your willing to change the wheel we have harnesses in stock for LS2 useing the LS2 injectors or LS6 style injectors
TPIS 952 448 5330
