LS2 Turbo Pistons
Measuring above the wrist pin area checks .146". Seems kinda thin.
Wiseco's check .187 in the same area.
Anyone have experience with these?
Thanks,
Jeff
Jeff Williams
Just my two cents.
Just my two cents.
Maybe the JE stuf is an eaiser option.
Nate
The top ring distance is .235" on the Mahle's the Wiseco's have slightly more.
I'm gonna run about 15lb. boost, maybe turn it up to 20 someday.
thanks
Jeff
Last night a Ford pick-up with a hot rod diesel wanted to run from a roll, I love when they pick on me. His Ford truck with the FASTDZL liscence plate thought my pistons were good!
Kurt
As for 4032, I guess I'll just say that 4032 is a step up from Hypereutectic, but not what most manufacturers use for Turbo or nitrous applications. If you don't detonate, it will live ok. Even in some high end applications, 4032 can be a "ok" choice. NHRA Prostock is one exception in "pro level" racing where 4032 is preferred over 2618...but this is usually because of the perfect tuning and a "weight reduction at all costs" mentality....try a set of pistons every 60 runs. Guys that were the "first 3rd gen in the 6's at over 200" were running 2618 alloy when they did it..
4032 is 3% lighter, has better wear "appearance" when pulled out of a run engine due to it's high silicon content. 2618 gets shiny and gets vertical scratches if the oil isn't kept clean, but for the most part maintains it's "shape". Installed clearance on each can be the same if the 2618 piston is engineered correctly. Things like offset pins can overcome the generalization that forged pistons (especially low silicon 2618) are noisy.
If you've ever seen an engine, with a dropped valve for instance, and the forged piston is a bunch of nickle sized fragments in the oilpan....that's 4032. If you've seen the piston wrapped around the valve head like taffy, that's 2618.
^^^ Great post!^^^^
Brian
Kurt
Many Many Many people with over 100K miles with 2618 alloy have had no ill effects. As long as the ring grooves are flat to begin with and the rings are good quality (flat themselves), vertical clearance in the land is not an issue. I've run between .0005 clearance up to .0025 vertical clearance with no changes in power...In fact, some of the latest o.e. race engines have begun to specifically open up the top groove clearance to allow the ring to twist more for better seal. The ring doesn't seal on the flat surface of the land anyway, it seals on the outer lower lip. As long as that stays "round", you're in good shape.
The original post is this...the engine may be run up to 20 lbs at some point. We ARE talking about an engine with 700 to 800hp potential EASILY. There is limited room for lands and .235 tops are well under the .300 that ANY piston maker would prefer for a boosted application given enough room. ONE tank of bad gas is enough to pop a thin .235 top land even with 2618 alloy, so why take the chance.
I guess my main point is at least 5 of the biggest and most respected players in aftermarket LS engine buildups ALWAYS use 2618. I'm taking the high road here and leaving the names of those companies out of this post. That's not what this post is about. You don't hear people whining about noisy engines from these respected engine builders. Every piston company in the U.S. (except one) uses 2618 alloy for boosted and nitrous applications. If you don't hear a lot of pissing and moaning over 2618 alloy pistons making noise (especially the offset wrist pin ones), why WOULDN'T a guy use 2618 alloy.
A 2618 piston will have enough wear in the ring land to lose hp in a 24hr race. I test them on the dyno before we send them, then re-dyno when they come back. The engine in a 24hr race has about 35 running hours(break-in, practice, race) on it when it gets back.
The "quality" of the pistons we use are very high, the material has nothing to do with the quality of the product. The material choice is done for many reasons, when we chose 4032 over 2618, cost and quality are not the reasons, the application of the engine and getting the best part is the only concern.
The piston in my truck is 4032 because we tested different materials and designs and this one is the best for my application. My engine in my truck does make over 800hp and 900ft lbs. It will flip 40,000 miles this weekend with the turbo on it. It has seen 15-20psi daily for its whole life. If JSWORKSTD's application is under 1,000hp, then the 4032 piston that he has will work for his application.
Kurt
-Bryan
To say that everyone on this forum has the same tuning ability and luck would be wrong though. I'd be remiss in recommending 4032 in this application. I've seen too many broken lands (every manufacturer and alloy) to "take a chance" on it when 2618 is available. It's just too destructive.
For the tech-heads here, the best of both worlds is 2618 with Boron Carbide groove treatment. It's a $350 option, but it's what the pro's run in endurance applicatons.
On land thickness our testing supports the pistons second land thickness is more important than top when using a "hell fire" or equal ring in the top groove.
Brian/Bryan
When you are testing the 4032 pistons, what type of failure do you see? Is it catastophic or just cracking? How many hours do they run before they fail? Do you run full throttle NA or boosted to cause the failure(approx HP/rpm).
Brian Nutter- Which piston company do you work for? Wiseco(guessing because of Ohio!).
Kurt
Mostly 99 percent of power adder stuff is 2618 that I have seen and in fact I didn't kow Mahle made a piston like that with 4032! I'm sure it will last and guys like Kurt at W2W are also pretty damn good tuners and much more experienced than most so I have no doubt whatsoever that his piston there is working for him but the leeway for any old tuner taking those pistons out with a crazy tune IS higher.
I also am not a fan of the thin Mahle top lands on the power adder stuff. It's great for lower power and NA but not so safe for big power adders and any tuning slipups!
We use and love the Wisecos because they are built like a tank with strong lands and good deck thickness and are still fairly light as well. They also have the inboard pin boss design that Mahle and some of the JEs use which uses a shorter and stiffer pin. You can opt up on the Wisecos also for a .170 wall tool steel pin if you want extra insurance for about another 100 or so.
